Joined: 1/2/2015(UTC) Posts: 2 Location: Aurora, Colorado USA
Hi, I need some help with the multi-coder. I have been recording 3 rooms, when I take the files and load them in VLC media player, they work fine. But when I try to load them into either Vegas or Davinci Resolve to edit, I get the not compatible file notice. I have tried all 4 formats (AV -MPEG-etc) and no luck. I have tried it on 2 different computer systems with the same result. I would appreciate any help. Thank you.
Joined: 11/27/2023(UTC) Posts: 137  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
I had a similar issue, and I raised the video bitrate to 50 and got the clips to work in Edius....try that and see if it works for your editing software
