RJF
#1 Posted : Monday, July 15, 2024 1:21:44 AM(UTC)
RJF
Hi !
I'm using vMix 4k with 3 displays (one laptop display + two external HDMI displays).
I was wondering if it's possible to assign shortcuts that will be active only for a specific display (or for a specific output/NDI) ?
Example with 2 cameras (1&2) and two external displays (A&B) :
Shortcut "1" put cam1 on display A only
Shotcut "F1" put cam1 on display B only
Shortcut "2" put cam2 on display A only (display B still shows cam1)
Shortcut "F2" put cam2 on display B only (now both displays shows cam2)
Thank you very much for your answer !
dmwkr
#2 Posted : Monday, July 15, 2024 4:36:23 AM(UTC)
dmwkr
Try using Mix Inputs:
