Shortcut active only for a specific display / output
Joined: 12/4/2016(UTC) Posts: 18   Location: Strasbourg Thanks: 3 times
Hi ! I'm using vMix 4k with 3 displays (one laptop display + two external HDMI displays). I was wondering if it's possible to assign shortcuts that will be active only for a specific display (or for a specific output/NDI) ?
Example with 2 cameras (1&2) and two external displays (A&B) : Shortcut "1" put cam1 on display A only Shotcut "F1" put cam1 on display B only Shortcut "2" put cam2 on display A only (display B still shows cam1) Shortcut "F2" put cam2 on display B only (now both displays shows cam2)
Thank you very much for your answer !
Thanks: 64 times Was thanked: 160 time(s) in 144 post(s)
