IAmAkkim
#1 Posted : Tuesday, June 25, 2024 5:22:06 AM(UTC)
IAmAkkim
As I continue to dig deeper and deeper into GT Designer - and I'm really enjoying what I've been able to accomplish in it - one thing I'm looking for / hoping for is a bit of a fine-tuning of the "Shadow" functionality.
In the end the pre-set options that exist are "alright" - but really lack the common functions that would make it really solid.
"Size" of the shadow as a slider would be helpful.
"Outline" as a shadow type would be exceptional.
"Offset" as an option would be nice as well (allowing the shadow to be moved slightly versus having to pick a corner)
Thanks,
--Micah
IAmAkkim
#2 Posted : Tuesday, June 25, 2024 11:22:41 PM(UTC)
IAmAkkim
....on another note, does anyone know if the COLOR of a SHADOW can be modified by a Datasource? I'm guessing not.. but really would be awesome if it could be somehow ;)
