GT
Feature Request - Shadow Enhancement
Joined: 10/6/2022(UTC) Posts: 8  Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
As I continue to dig deeper and deeper into GT Designer - and I'm really enjoying what I've been able to accomplish in it - one thing I'm looking for / hoping for is a bit of a fine-tuning of the "Shadow" functionality.
In the end the pre-set options that exist are "alright" - but really lack the common functions that would make it really solid.
"Size" of the shadow as a slider would be helpful. "Outline" as a shadow type would be exceptional. "Offset" as an option would be nice as well (allowing the shadow to be moved slightly versus having to pick a corner)
Thanks, --Micah
....on another note, does anyone know if the COLOR of a SHADOW can be modified by a Datasource? I'm guessing not.. but really would be awesome if it could be somehow ;)
GT
