Dave.S
#1 Posted : Thursday, June 13, 2024 10:52:24 PM(UTC)
Dave.S
Is there a trigger event defined for when a submix is cut/fade (and not brought live)
nikosman88
#2 Posted : Friday, June 14, 2024 12:46:36 AM(UTC)
nikosman88
Greece
Hello. What is the goal you try to do? I think via scripting something can be done. Or if you use bitfocus companion you can setup a trigger events-->on variable change-->variable to watch "mix 2 Program" to do any action you need
Dave.S
#3 Posted : Friday, June 14, 2024 12:55:09 AM(UTC)
Dave.S
I was looking to effect a tally in a Vcall MV return. I think Companion is probably the best choice for me as I can't see any trigger event available for the mixer.
