Submix trigger for cut/fade
Is there a trigger event defined for when a submix is cut/fade (and not brought live)
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 97 time(s) in 93 post(s)
Hello. What is the goal you try to do? I think via scripting something can be done. Or if you use bitfocus companion you can setup a trigger events-->on variable change-->variable to watch "mix 2 Program" to do any action you need
Originally Posted by: nikosman88  Hello. What is the goal you try to do? I think via scripting something can be done. Or if you use bitfocus companion you can setup a trigger events-->on variable change-->variable to watch "mix 2 Program" to do any action you need I was looking to effect a tally in a Vcall MV return. I think Companion is probably the best choice for me as I can't see any trigger event available for the mixer.
