DJLTC
#1 Posted : Thursday, June 13, 2024 5:48:54 PM(UTC)
DJLTC
I am using APIs to run shortcuts for me. I want an API to play an audio file that is input 100. I haven’t figured out how to make it work.
Am I on the right track here…?
I added an audio input.
I clicked Audio for the input 100 to enable the input audio.
I created a shortcut for input 100, but I’m not sure what the function should be. It can’t be cut or fade, etc because input 100 is audio only and I don’t want to change what’s on the screen.
I thought maybe it should be an overlay. So I enabled overlay 4 for input 100.
If I click the play button for input 100, it plays just fine. I tried every function related to Overlay4 and all of the audio functions. I pointed them to input 100. None of them played the audio in input 100.
Can someone please tell me how to make a shortcut to play an audio input so I give the command to my API?
Thanks for taking the time to read this. I look forward to your replies.
DJ
dmwkr
#2 Posted : Thursday, June 13, 2024 6:25:25 PM(UTC)
dmwkr
The function to play an input is... "Play". :) Depending on what you are trying to achieve, you can also add "Restart" first to your shortcut, so to make sure the input starts from the beginning.
thanks 1 user thanked dmwkr for this useful post.
DJLTC on 6/15/2024(UTC)
DJLTC
#3 Posted : Saturday, June 15, 2024 2:23:45 PM(UTC)
DJLTC
It worked! Many thanks!
