Joined: 11/21/2020(UTC) Posts: 36  Location: Zuerich Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
Very strange analog audio problem with the Aja i/o x3: The only driver available is the Kona ASIO driver, which I selected. To test the analog inputs through the DB25 connector, I used a DB25 to XLR adapter and measured the pins with a multimeter and the wiring of the DB25 is 100% correct (Tascam Standard). In the Aja control panel, I set the audio configuration in the Aja control panel to 8 inputs and created a mono audio input for each Kona ASIO channel in vMix to test where the signal is going. ASIO input 1 is not showing up anywhere, ASIO input 2 is the physical input 1 on the DB25 connector, ASIO input 3 is then physical input 2 on the DB25 connector. And so on (ASIO Input 9 is physical input 8). Can someone help me out here?
