Showcase
3x3 Zoom-In Buttons for vMix 27 (Free Template)
Joined: 4/3/2022(UTC) Posts: 32  Thanks: 5 times Was thanked: 9 time(s) in 8 post(s)
Hey all. Posting here to share a free template I made for vMix 27 and Companion 3.3.0+ where you can move between 54 different zoom looks on one Stream Deck XL (9 anchor positions and 6 zoom levels, but it also includes customizable durations for the merge moves). As an added bonus, the buttons will also grey out while a merge is in progress, so that you know when it's safe to make another move.
Joined: 6/18/2019(UTC) Posts: 27   Thanks: 2 times Was thanked: 3 time(s) in 3 post(s)
Thank you, this is very useful! If anyone can't get it to work, I had to manually create a few custom variables in Companion with these exact names:
merge_duration zoom_level pan_x pan_y hot_zooms
I also needed to make a slight change to the Set Zoom 150% button. It was programmed differently from the others and wasn't triggering a Feedback color. Otherwise, this works great!
 1 user thanked kmedia for this useful post.
Originally Posted by: kmedia  Thank you, this is very useful! If anyone can't get it to work, I had to manually create a few custom variables in Companion with these exact names:
I also needed to make a slight change to the Set Zoom 150% button. It was programmed differently from the others and wasn't triggering a Feedback color. Otherwise, this works great! Thanks for calling out the 150% feedback not working. I've gone ahead and fixed that now! For the custom variables, that should only be true if you're importing the buttons as a page onto an existing config, and you're correct that you'll need to add the custom variables yourself if that's the case. (hopefully in a future Companion version it will be possible to import a page w/ custom variables and check for any collisions with existing custom variables)
Showcase
