bdrady
#1 Posted : Friday, May 17, 2024 12:05:58 PM(UTC)
bdrady
All was working just fine. I upgraded vMix to 27.0.0.76X64 and now it is not recognizing my camera. I connect the camera to my computer using CamLink. The camera works but I am not getting any images in vMix from the camera.
Any suggestions are appreciated.
Thank you!
nikosman88
#2 Posted : Friday, May 17, 2024 8:27:14 PM(UTC)
nikosman88
Greece
Hello.I dont know if this is also your situation that happened but I have seen before some days a post with same problem in a fb group. The problem was not the vmix but an update in windows 11 that caused it. After uninstalled it,the guy said that cameras work ok again
bdrady
#3 Posted : Friday, May 17, 2024 11:13:56 PM(UTC)
bdrady
I will try that and let you know if it works. Thanks!
By the way, my ability to join the Facebook group is pending, so I am unable to post in it yet. If you could post for me and see if there are any other details or solutions, that would be amazing!
nikosman88
#4 Posted : Saturday, May 18, 2024 12:43:18 AM(UTC)
nikosman88
Greece
As solution suggested to un-install the latest 15/5/24 windows 11 update
bdrady
#5 Posted : Saturday, May 18, 2024 12:53:31 AM(UTC)
bdrady
Thank you. I don't see that there was an update on May 15th but that certainly corresponds to my issue. I will have to dive deeper.
[img=https://drive.google.com/file/d/1PalqDs2TW6eyoN8dbppDEjg4uuS2zzQs/view?usp=drive_link]Diving[/img]
bdrady
#6 Posted : Sunday, May 19, 2024 9:37:53 AM(UTC)
bdrady
Thank you for the suggestion. I uninstalled the May 15th updates but I still am not having any success. I can use my computer camera but the quality is not nearly as good as my sony.
