	Hardware Compatibility
	vMix 27.0.0.76X64 is not recognizing my camera
                All was working just fine. I upgraded vMix to 27.0.0.76X64 and now it is not recognizing my camera. I connect the camera to my computer using CamLink. The camera works but I am not getting any images in vMix from the camera.
  Any suggestions are appreciated.
  Thank you!
 Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 96 time(s) in 92 post(s)
                Hello.I dont know if this is also your situation that happened but I have seen before some days a post with same problem in a fb group. The problem was not the vmix but an update in windows 11 that caused it. After uninstalled it,the guy said that cameras work ok again
                I will try that and let you know if it works. Thanks!
  By the way, my ability to join the Facebook group is pending, so I am unable to post in it yet. If you could post for me and see if there are any other details or solutions, that would be amazing!
                Originally Posted by: bdrady  I will try that and let you know if it works. Thanks!
  By the way, my ability to join the Facebook group is pending, so I am unable to post in it yet. If you could post for me and see if there are any other details or solutions, that would be amazing!  As solution suggested to un-install the latest 15/5/24 windows 11 update
                Thank you. I don't see that there was an update on May 15th but that certainly corresponds to my issue. I will have to dive deeper.
  [img=https://drive.google.com/file/d/1PalqDs2TW6eyoN8dbppDEjg4uuS2zzQs/view?usp=drive_link]Diving[/img]
                Thank you for the suggestion. I uninstalled the May 15th updates but I still am not having any success. I can use my computer camera but the quality is not nearly as good as my sony.
