imagebotique
#1 Posted : Wednesday, May 8, 2024 6:32:44 AM(UTC)
imagebotique
Screenshot 2024-05-07 162818.png (120kb) downloaded 0 time(s).
I cannot seem to get past this error message. I have done a full uninstall of vmix through the control panel in addition to wiping all of the vmix folders from windows. I have no antivirus software running other than the windows software which I have even tried to disable. Vmix seems to install fine but when I open vmix I get this error message. I can click continue but I just get the vmix 27 loading screen indefinitely.
mavik
#2 Posted : Wednesday, May 8, 2024 7:57:59 AM(UTC)
mavik
Was thanked: 180 time(s) in 162 post(s)
Have you tried to disable your AV software or set an exception for vMix?
sinc747
#3 Posted : Thursday, May 9, 2024 12:47:35 AM(UTC)
sinc747
Was thanked: 201 time(s) in 167 post(s)
Several suggestions...
Run vMix Diagnostics. It was installed when you installed vMix.
Check to see if you have applications or drivers called Nahimic or Sonic Studio. They can interfere with vMix operation.
Also might try downloading vMix again from the vMix website, then try install again.
Good luck!
- Tom
imagebotique
#4 Posted : Thursday, May 9, 2024 1:57:43 AM(UTC)
imagebotique
Screenshot (1).png (327kb) downloaded 1 time(s).
Thanks Tom for the reply, I have done that as well, full wipe of vmix from computer form control panel as well as deleting all folders from windows. Runing Vmix Diagnostics this is all that shows up.
Do not have Sonic Studio or Nahmic running and had vmix running fine on this machine just before this latest upgrade.
