Joined: 5/27/2017(UTC) Posts: 93   Location: Greater St Louis Area Thanks: 67 times Was thanked: 20 time(s) in 13 post(s)
One popular method of structuring a production in Zoom is to use the Meeting format for simple entry and triage of guest tech issues, and move cast into a Production Breakout Room. I've been able to get Zoom Inputs to work from Breakouts, but not consistently. I am told that, while it's often achievable, it's not technically supported. My "ask" is to support this workflow, which is available in the Video SDK.
Currently tools successfully pulling video from breakouts are ZoomISO, MimoLive, Wirecast... I'll ALWAYS prefer using vMix over these, but nonetheless, they are being used in this workflow.
Come on, folks! Let's lock down support for important features we need to have!
Best,
Chad
Disclosure: Support indicated I should post here so they could gauge community interest.
Joined: 4/14/2020(UTC) Posts: 17  Location: Dallas, TX Thanks: 5 times
+1 on this. We do production in a similar way to what Chad described, so having the vmix zoom integration officially supported would definitely be beneficial to us.
Joined: 2/21/2021(UTC) Posts: 5  Location: Seattle Thanks: 3 times
Originally Posted by: cchhita  +1 on this. We do production in a similar way to what Chad described, so having the vmix zoom integration officially supported would definitely be beneficial to us. +1
Joined: 1/13/2010(UTC) Posts: 5,350  Location: Gold Coast, Australia Was thanked: 4759 time(s) in 1633 post(s)
To clarify, we do use the SDK in the same way as the other apps mentioned. However as you have noticed recording feeds when moving between breakout rooms can be inconsistent, and this is something we have no control over and would also be the same if using those other apps in the same way.
Note that these issues exist regardless of which app is being used. It ultimately comes down to SDK quirks when using the Streaming and/or Recording capture modes in conjunction with breakout rooms.
It's possible I'm missing the meaning above. We join the breakout for access to the video feeds in that breakout. If a contributor exits the breakout, we no longer need their signal. If we exit, we're no longer processing video.
The extent of the corrective action I've had to take using a tool like ZoomISO is to disable and enable the record engine (kick it). Noting that I can't do that in vMix at this time as well... are these two matters related? I have a feature request in for that, as well! :)
Thank you. I truly appreciate all your work and the excellent software you provide.
Best,
Chad
Joined: 1/2/2025(UTC) Posts: 6  Location: Kuala Lumpur Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
it would be great if breakout room features can be supported
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Joined: 7/31/2017(UTC) Posts: 9   Location: Ontario, Canada Thanks: 7 times Was thanked: 2 time(s) in 2 post(s)
+1 From me and from many of our Zoom Test Kitchen community members.
