Overlay only shown on Output 1
Hello, I've just set up a show with 4 external outputs (27.0.0.69) and found out, that my lower thirds on overlay 1 are only shown on output 1. I rechecked it on all overlay-channels, but it is the same. All overlays and stingers are enabled on every output, but not shown on 2, 3 and 4. Can you guys please check that?
Originally Posted by: H.Petersen  Hello, I've just set up a show with 4 external outputs (27.0.0.69) and found out, that my lower thirds on overlay 1 are only shown on output 1. I rechecked it on all overlay-channels, but it is the same. All overlays and stingers are enabled on every output, but not shown on 2, 3 and 4. Can you guys please check that?  Screenshot 2024-04-15 224801.jpg (55kb) downloaded 0 time(s).
As i wrote, all overlays and stingers are activated on all outputs :)
Originally Posted by: H.Petersen  As i wrote, all overlays and stingers are activated on all outputs :)
OK, sorry Have you tried with updating to the latest version (.72)?
No, we are right now on production, starting tomorrow. I think i will try the .72 right after that. Thank you.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Are you sending "Output" to Outputs 2, 3, 4? Or specific Inputs?
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
if you look at doggy's picture, the overlays in his example only work on Output 1,2 and 3. These are set to „Output“.
Output 4 is Set to Input10. Overlays are don't possible here because vmix only sends overlays to the „main mix“ (PGM)
