Seba
#1 Posted : Tuesday, April 2, 2024 8:01:57 PM(UTC)
Seba
Poland
Hello. I'm working with the PS5 UFC broadcast on Twitch. And sometimes such problems arise with sound (https://clips.twitch.tv/SincerePiliableSangTwitchRPG-roQOGEalhKfyhiHm). The wires are all intact, the problem occurs only during the broadcast, when exiting the TV everything is ok.
And why does the stream go at 4700-4800 bitrate if the settings are 6000
mavik
#2 Posted : Tuesday, April 9, 2024 7:23:36 AM(UTC)
mavik
Can you detail on how your signal flow is, how you capture.
The bitrate depends on content, encoder and server.
kuuminsh
#3 Posted : Tuesday, April 9, 2024 9:37:37 PM(UTC)
kuuminsh
Latvia
What is the sound interface and how big is the buffer?
Seba
#4 Posted : Friday, April 12, 2024 7:39:05 PM(UTC)
Seba
Poland
Hi
We don't use microphones, only cameras that broadcast video. Sound and video goes from the ps5 to the splitter and then from the splitter to the capture card(DeckLink Quad HDMI Recorder). Two cameras are also attached to the capture card.
The problem looks like this and it lasts for a few seconds then everything works fine again.
https://clips.twitch.tv/...atChest-CINE5vLeUaJ7jt3C
https://clips.twitch.tv/...DBstyle-5ZxwpHIoHoW2N9AA
Best
Seba
Similar Topics
input sound problems (General Discussion)
by Bill Lord 9/11/2023 3:50:31 AM(UTC)
