Hello. I'm working with the PS5 UFC broadcast on Twitch. And sometimes such problems arise with sound (https://clips.twitch.tv/SincerePiliableSangTwitchRPG-roQOGEalhKfyhiHm). The wires are all intact, the problem occurs only during the broadcast, when exiting the TV everything is ok. And why does the stream go at 4700-4800 bitrate if the settings are 6000
Joined: 4/23/2017(UTC) Posts: 1,444  Location: Germany Thanks: 3 times Was thanked: 192 time(s) in 172 post(s)
Can you detail on how your signal flow is, how you capture.
The bitrate depends on content, encoder and server.
Joined: 2/8/2023(UTC) Posts: 24  Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
What is the sound interface and how big is the buffer?
Originally Posted by: mavik  Can you detail on how your signal flow is, how you capture.
The bitrate depends on content, encoder and server. Hi We don't use microphones, only cameras that broadcast video. Sound and video goes from the ps5 to the splitter and then from the splitter to the capture card(DeckLink Quad HDMI Recorder). Two cameras are also attached to the capture card. The problem looks like this and it lasts for a few seconds then everything works fine again. https://clips.twitch.tv/...atChest-CINE5vLeUaJ7jt3Chttps://clips.twitch.tv/...DBstyle-5ZxwpHIoHoW2N9AABest Seba
