fgolman
#1 Posted : Tuesday, March 19, 2024 6:36:00 AM(UTC)
fgolman
Tried this (based upon AI built code):
' Create a WshShell object
Set objShell = CreateObject("WScript.Shell")
' Specify the path to your batch file
batchFilePath = "C:\path\to\your\batch\file.bat"
' Run the batch file
objShell.Run batchFilePath, 1, True
Will not let me save, gives error that set and let are no longer supported. How can I accomplish this?
Thanks in advance for suggestions.
Fritz Golman
iHeartMedia
fgolman
#2 Posted : Tuesday, March 19, 2024 12:56:10 PM(UTC)
fgolman
UPDATE
This alternative script worked!
Dim psi As New ProcessStartInfo("c:\test.bat")
psi.RedirectStandardError = True
psi.RedirectStandardOutput = True
psi.CreateNoWindow = False
psi.WindowStyle = ProcessWindowStyle.Hidden
psi.UseShellExecute = False
Dim process As Process = Process.Start(psi)
Not quite as simple but effective!
Fritz Golman
iHeartMedia
#3 Posted : Tuesday, March 19, 2024 3:31:06 PM(UTC)
Originally Posted by: fgolman Go to Quoted Post
UPDATE
Fritz Golman
iHeartMedia
Could it be a forum search would have been quicker ans simpler then AI ?
https://forums.vmix.com/...ng-for-Dummies#post88357
https://forums.vmix.com/...ng-for-Dummies#post93904
fgolman
#4 Posted : Tuesday, March 19, 2024 8:04:26 PM(UTC)
fgolman
I did search but but for whatever reason was unsuccessful.
