Launching a batch file from script
Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
Tried this (based upon AI built code):
' Create a WshShell object Set objShell = CreateObject("WScript.Shell")
' Specify the path to your batch file batchFilePath = "C:\path\to\your\batch\file.bat"
' Run the batch file objShell.Run batchFilePath, 1, True
Will not let me save, gives error that set and let are no longer supported. How can I accomplish this?
Thanks in advance for suggestions.
Fritz Golman iHeartMedia
UPDATE
This alternative script worked!
Dim psi As New ProcessStartInfo("c:\test.bat") psi.RedirectStandardError = True psi.RedirectStandardOutput = True psi.CreateNoWindow = False psi.WindowStyle = ProcessWindowStyle.Hidden psi.UseShellExecute = False
Dim process As Process = Process.Start(psi)
Not quite as simple but effective!
Could it be a forum search would have been quicker ans simpler then AI ? https://forums.vmix.com/...ng-for-Dummies#post88357https://forums.vmix.com/...ng-for-Dummies#post93904
I did search but but for whatever reason was unsuccessful.
