Kibim
#1 Posted : Wednesday, March 6, 2024 8:00:53 AM(UTC)
Kibim
Hi All, hoping for a simple solution here.
I have a fairly big live json data source i pull in that updates every 300ms (live from a track timing system) and I'd like to be able to show 2 competitors, and thier time differences, on a single slide.
I can do a select row, but that only gives me 1 competitor. I've looked at the 'convert rows to columns, but i get 30+ columns as is from the data-source, and i still can't use a Rowselect, or even better a DataSourceNextRow.
If this has been covered somewhere else, apologies, i couldn't find a solution.
#2 Posted : Wednesday, March 6, 2024 12:34:11 PM(UTC)
- Open the datasource twice
Kibim
#3 Posted : Wednesday, March 6, 2024 7:04:03 PM(UTC)
Kibim
oh the simplicity. too easy. thank you.
