GT
DataSource RowSelected Plus 1
Joined: 6/6/2015(UTC) Posts: 21 Location: South Africa
Hi All, hoping for a simple solution here.
I have a fairly big live json data source i pull in that updates every 300ms (live from a track timing system) and I'd like to be able to show 2 competitors, and thier time differences, on a single slide. I can do a select row, but that only gives me 1 competitor. I've looked at the 'convert rows to columns, but i get 30+ columns as is from the data-source, and i still can't use a Rowselect, or even better a DataSourceNextRow.
If this has been covered somewhere else, apologies, i couldn't find a solution.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
- Open the datasource twice
oh the simplicity. too easy. thank you.
GT
