Joined: 4/27/2019(UTC) Posts: 7  Location: Ann Arbor, Michigan
I used NDI to pull in a second monitor so I could put it on the show. Worked great, and I can cut to that monitor to show off web sites, etc. The problem is today I went to play a video, and while the video worked as expected, the audio that accompanies the video did not come in. I thought I could just click the "Audio" button on that input to make the audio available, but the audio button isn't clickable at all on that input. How do I add the audio?
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
Oh wow, thank you so much! That is exactly what I needed! Yes I used local desktop capture.
Brad
