TL68
#1 Posted : Tuesday, February 13, 2024 10:29:38 PM(UTC)
TL68
Sweden
Hi all!
I am looking for a way or maybe shortcut to play a selected event AND all the following events i the event list in the replay pane.
I would find this useful while going through the events preparing them to be exported as a highlights reel.
Right now I only find ways to play all events or selected events.
But usually while editing the events for a reel, I play through them and maybe want to stop at some event to edit an it and then keep on playing from there.
Hope I just missed an existing shortcut.
Play events from selected
thanks 1 user thanked TL68 for this useful post.
Ario on 3/15/2024(UTC)
#2 Posted : Tuesday, February 13, 2024 11:15:07 PM(UTC)
Originally Posted by: TL68 Go to Quoted Post
Hi all!
no shortcut is available for that right now.
Might be able using scripting by checking which is currently selected and add the ID's of subsequent clips as they are ordered in the list to create the ReplayPlayEventsByID function
TL68 on 2/14/2024(UTC)
coyut
#3 Posted : Tuesday, March 5, 2024 7:29:18 PM(UTC)
coyut
Why not just copy the needed clips to a new list and play from there?
TL68
#4 Posted : Tuesday, March 5, 2024 7:38:40 PM(UTC)
TL68
Sweden
Thanks for the suggestion! But this workflow will be going through editing quite a few replays before saving them into a compilation.
Having to create a new list and copy for each time you want to "play all replays from here" could mean a lot of copy and pasting.
Will try but not sure it is going to work that well for us.
AudioGreg
#5 Posted : Friday, March 8, 2024 2:33:39 AM(UTC)
AudioGreg
Was thanked: 23 time(s) in 20 post(s)
I was just thinking about this yesterday. With mouse/kb (ctrl click or shift click) you can easily select any combination of events in the replay tab, then play selected as a sort of makeshift playlist. Very handy, but not if your TD is hogging the mouse/kb. Having equivalent shortcuts so one can do it on a replay controller would be most helpful.
thanks 2 users thanked AudioGreg for this useful post.
TL68 on 3/8/2024(UTC), Ario on 3/15/2024(UTC)
