filmmaker75
#1 Posted : Thursday, February 8, 2024 12:53:18 AM(UTC)
filmmaker75
I currently have a PC with this configuration for 1080p25 projects:
MB Gigabyte Z370 HD3
CPU Intel i7-8700K
RAM 32GB DDR4 (2x16)
GPU EVGA GTX 1060 6GB
SSD SATA 500GB for O.S. (Windows 10)
CAPTURE CARD Decklink Duo 2
I would like to add a second Decklink Duo 2 to have 8 SDI inputs in total. With the current configuration the PCI-EX lines are not enough for me. What motherboard and processor can I use to make everything work?
Kayo33
#2 Posted : Tuesday, March 5, 2024 8:11:55 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
you just need to change the MB
on actual Gigabyte Z370 HD3, except the pciex16 for GPU, everything else depends on the chipset in dmi 3.0 x4
so between the capture cards (pcie 2.0 x4) and the ssd (pcie 3.0 x4 + sata 6 + lan + usb) it will get stuck at some point
and vmix advises to use cpu managed pcie slots for capture cards
Gigabyte Z370 HD3
you have to take a motherboard with 3 slots managed by the cpu
like MSI MEG Z390 Ace
with 16 cpu lanes in x8/x4/x4 (GPU/ BMD Duo 1/ BMD Duo 2)
msi meg z790 ace block diagram.png (522kb) downloaded 79 time(s).
then either 1 x m.2 ssd for windows
or 1 x sata III ssd for rec
pay attention to the combinations of ports used
msi z90 ssd-sata_page-0001.jpg (294kb) downloaded 80 time(s).
bonus : later GPU upgrade for RTX 4xxx if the power supply allows it
and show can go on
