fdooman
#1 Posted : Saturday, February 3, 2024 10:16:26 AM(UTC)
fdooman
Hello all
Is there a way to create single key shortcut with 2 function Off/On audio on inputs? or I have to use 2 keys. Thanks for any help.
nikosman88
#2 Posted : Saturday, February 3, 2024 11:40:52 AM(UTC)
nikosman88
Rank:: Advanced Member
Greece
Originally Posted by: fdooman Go to Quoted Post
Hello all
Hello. There is a shortcut that called "Audio" and toggles the green button (on/off) audio of any input when you press it. Also same function does the "Audio Bus" shortcut if you need for example to mute an exactly audio bus and not the whole audio from a specific input
fdooman
#3 Posted : Saturday, February 3, 2024 1:40:17 PM(UTC)
fdooman
Hello all
Thanks a bunch, will try it. This is for talk back with host to prevent audio getting to output master.
fdooman
#4 Posted : Saturday, February 3, 2024 2:01:55 PM(UTC)
fdooman
Thank you so very much nikosman88. you were right on spot. Now works perfectly.
