Joined: 6/16/2018(UTC) Posts: 30 Location: LOS ANGELES
Hello all Is there a way to create single key shortcut with 2 function Off/On audio on inputs? or I have to use 2 keys. Thanks for any help.
Originally Posted by: fdooman  Hello all Is there a way to create single key shortcut with 2 function Off/On audio on inputs? or I have to use 2 keys. Thanks for any help. Hello. There is a shortcut that called "Audio" and toggles the green button (on/off) audio of any input when you press it. Also same function does the "Audio Bus" shortcut if you need for example to mute an exactly audio bus and not the whole audio from a specific input
Originally Posted by: nikosman88  Originally Posted by: fdooman  Hello all Is there a way to create single key shortcut with 2 function Off/On audio on inputs? or I have to use 2 keys. Thanks for any help. Hello. There is a shortcut that called "Audio" and toggles the green button (on/off) audio of any input when you press it. Also same function does the "Audio Bus" shortcut if you need for example to mute an exactly audio bus and not the whole audio from a specific input Thanks a bunch, will try it. This is for talk back with host to prevent audio getting to output master.
Thank you so very much nikosman88. you were right on spot. Now works perfectly.
