SDKUCSS
#1 Posted : Friday, January 12, 2024 4:46:50 AM(UTC)
SDKUCSS
Is it possible to have a vMix clock that counts to a specific time, more than 24 hours? If it’s Monday, how do you build a clock that countdown to Wednesday at 3pm? I’ve tried using different combinations of the MM:DD:YYYY but I can’t figure out how to you configure the syntax?
#2 Posted : Friday, January 12, 2024 5:24:00 AM(UTC)
GIS !
https://forums.vmix.com/...own-to-midnight#post3310
https://forums.vmix.com/...ountdown-timer-with-days
SDKUCSS
#3 Posted : Friday, January 12, 2024 9:04:18 AM(UTC)
SDKUCSS
Thanks for the help Doggy, but I don’t think I explained myself correctly. For the countdown display, I’d like to have the total hours until the event. So it would be greater than 24 hours away. So an event happening three days from now would add 72 hours to the clock and it would display as “75:30:10” with hours, minutes and seconds displayed as the countdown.
nikosman88
#4 Posted : Friday, January 12, 2024 9:45:45 AM(UTC)
nikosman88
Greece
Hello i dont know if possible directly in vmix but i can suggest you a workaround to do what you need. You can use this app https://github.com/dlamon1/clockotron/releases/
it works with vmix simple text title in which you can add as many hours you need
#5 Posted : Friday, January 12, 2024 12:42:57 PM(UTC)
vMix Script:
Code:
Dim enddate As DateTime = DateTime.Parse("2024-1-15 04:00:00")
Dim startdate As DateTime
Dim ts As TimeSpan
Dim count as string
Do while true
startdate = DateTime.Parse(Date.Now)
ts = enddate.Subtract(startdate)
count=CStr((ts.Days*24) + CStr(ts.Hours)) & " Hrs, " & CStr(ts.Minutes) & " min, " & CStr(ts.Seconds) & " sec"
'API.Function("SetText",Input:="14",SelectedName:="Headline.Text",Value:=count)
console.writeline(count)
sleep(1000)
loop
