karensox
#1 Posted : Monday, December 24, 2012 11:44:21 PM(UTC)
karensox
I want to make a countdown timer and found that it can be created by using a Title and entering {0:6:00PM|hh:mm:ss}.
This works great for most times, however when trying to countdown to midnight it doesn't work. I tried the following:
• {0:12:00AM|hh:mm:ss}
• {0:00:00AM|hh:mm:ss}
and neither worked - it just displayed "12:00:00". Is there another way to countdown to midnight?
Also, when I was testing with counting down to times such as 6pm, once the countdown time is within the hour (eg: only 12 minutes to go), the hour on the counter reverts to "12" instead of "0". I realise this can be fixed by just using the mm:ss format but wanted to let you know.
Love the software - very user friendly and intuitive!
Karen
#2 Posted : Tuesday, December 25, 2012 1:13:15 AM(UTC)
Hi Karen,
There does appear to be a bug when setting the countdown to 12:00AM. It should be fixed in the next release.
As a workaround you could set the time to:
{0:11:59:59PM|HH:mm:ss}
Which would only be one second off.
Note the capital HH which should also fix the issue of reverting to 12 during the last hour.
#3 Posted : Tuesday, December 25, 2012 1:26:35 AM(UTC)
Hi Karen,
Just had another look, you can actually enter the full date to fix this issue.
For example:
{0:25 December 2012 12:00 AM|HH:mm:ss}
Hope this helps!
karensox on 12/25/2012(UTC), stigaard on 7/19/2016(UTC)
karensox
#4 Posted : Tuesday, December 25, 2012 1:55:43 AM(UTC)
karensox
Fantastic! Thanks Martin!
