fgolman
#1 Posted : Saturday, January 6, 2024 1:41:10 AM(UTC)
fgolman
I noticed that the scripting engine doesn't gracefully handle when there are preset changes.
Specifically, I've got open network ports in my script for control communications and if a new preset is loaded it won't gracefully close the connection and the next script will fail because it's still open.
OR if there was a way to trap when a preset change is called, that would be a solution as we could force closure of any open resources before releasing back with a stop command. Likely the change preset condition would be useful for many other things as well.
Thank you!
Fritz Golman
iHeartMedia
#2 Posted : Saturday, January 6, 2024 1:50:39 AM(UTC)
Thank you!
Fritz Golman
iHeartMedia
Guess you are refering to your UDP use in scripts .
Close vMix and start it again by selecting your preset, or or stop the script (close the connection) first before loading another preset
