Feature Requests
Close network ports on preset load
Joined: 3/30/2023(UTC) Posts: 126  Location: Chicago Thanks: 11 times Was thanked: 6 time(s) in 5 post(s)
I noticed that the scripting engine doesn't gracefully handle when there are preset changes.
Specifically, I've got open network ports in my script for control communications and if a new preset is loaded it won't gracefully close the connection and the next script will fail because it's still open.
OR if there was a way to trap when a preset change is called, that would be a solution as we could force closure of any open resources before releasing back with a stop command. Likely the change preset condition would be useful for many other things as well.
Thank you!
Fritz Golman iHeartMedia
Originally Posted by: fgolman  I noticed that the scripting engine doesn't gracefully handle when there are preset changes.
Thank you!
Guess you are refering to your UDP use in scripts . Close vMix and start it again by selecting your preset, or or stop the script (close the connection) first before loading another preset
Feature Requests
