rickvoskamp
#1 Posted : Monday, January 1, 2024 3:31:11 AM(UTC)
rickvoskamp
Hi all, I’m searching for a solution to get the next result:
So I want the name of the players in two types of text formatting or different colors. So I can visual ‘split’ the names of the players.
For example like this:
First Surname.
I just want to use one text field in GT and push the data (the name) into the field by using the API.
Is there someone that know a ‘solution’ already?
Thank you all!
#2 Posted : Monday, January 1, 2024 4:13:05 AM(UTC)
First Surname.
Thank you all!
This is not an option with GT title where one can mix and match fonts and colors in 1 single textblock. has been adressed a few times in this forum
Is possible with legacy XAML titles though
https://forums.vmix.com/...xt-field-sizes#post87136
rickvoskamp
#3 Posted : Monday, January 1, 2024 9:21:18 PM(UTC)
rickvoskamp
Because the type of animations available in GT I want to use GT titles instead of XAML.
I don’t know if there are more people that have this request?
#4 Posted : Monday, January 1, 2024 10:12:20 PM(UTC)
Too bad (currently)
GT designer makes it simple to design something but at the same time is not as powerfull as XAMl. HTML5 is also an option , with user simplicity and userfriendlyness often comes less flexibility or optional trickery.
When i said possible with XAML it means its a trick using multiple textblocks put together looking like one . Also said it has been adressed a few times in this forum so yes more have looked for such request.
textblocks in GT or XAML are like little notepad files; one font one color , stick enough of them together and one can give the impression they are like one Word document or a HTML line of text
You asked for a solution to get the result but GT titles can currently not give this to you so a few (cheap) alternativs where given. There is alos quite a few external software alternatives if one is willing to spend some substancial amount of $$ for them
quick and dirty XAML example
vMix Capture 01 January 2024 14-19-57.png (28kb) downloaded 29 time(s).
and XAML code for it
Code:
<UserControl x:Class="MultiText"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             mc:Ignorable="d" Width="1920" Height="1080" xmlns:my="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary">
<Grid >
           <Grid Margin="235,165,137,311">
            <StackPanel Orientation="Horizontal" Margin="10,10,96,477.765" >
                <TextBlock x:Name="left1"  Background="#FF937373"  FontFamily="Courier New" FontSize="72" VerticalAlignment="Top" Height="79" Foreground="#FFFDFDFD" Margin="3,0,10,0" Padding="16,0,12,0"  Text="Left1"  />
                <TextBlock x:Name="right1" Text="Right1 Longer" Background="Red" FontWeight="Normal" FontSize="72" VerticalAlignment="Top" ScrollViewer.CanContentScroll="True" Height="79" Foreground="#FFF0F011" FontFamily="Arial" Padding="21,0,18,0" Margin="0,0,7,0" />
            </StackPanel>
            <StackPanel Orientation="Horizontal" Margin="10,106,90,380.265" >
                <TextBlock x:Name="left2"  Background="#FF937373"  FontFamily="Courier New" FontSize="72" VerticalAlignment="Top" Height="79" Foreground="#FFFDFDFD" Margin="0,0,10,0" Padding="16,0,12,0"  Text="Left2 +"  />
                <TextBlock x:Name="right2" Text="Right2 +" Background="Red" FontWeight="Normal" FontSize="72" VerticalAlignment="Top" ScrollViewer.CanContentScroll="True" Height="79" Foreground="#FFEAEA15" FontFamily="Arial" Padding="21,0,18,0" />
            </StackPanel>
            <StackPanel Orientation="Horizontal" Margin="10,202,87,281.265" >
                <TextBlock x:Name="left3"  Background="#FF937373"  FontFamily="Courier New" FontSize="72" VerticalAlignment="Top" Height="79" Foreground="#FFFDFDFD" Margin="0,0,10,0" Padding="16,0,12,0"  Text="Left3 longer"  />
                <TextBlock x:Name="right3" Text="Right3" Background="Red" FontWeight="Normal" FontSize="72" VerticalAlignment="Top" ScrollViewer.CanContentScroll="True" Height="79" Foreground="#FFC5CD17" FontFamily="Arial" Padding="21,0,18,0" />
            </StackPanel>
         </Grid>
</Grid>
</UserControl>
Guest (4)
