sphbecker
#1 Posted : Wednesday, December 27, 2023 4:37:23 AM(UTC)
sphbecker
I am considering buying vMix to replace OBS for our quarterly company broadcast. I downloaded the trial and everything works as expected, however, I am unsure if I will need HD or 4K for my external output needs.
I wish there was a way to set the trial to simulate a specific edition for testing purposes.
I need 1 Fullscreen output and 1 External (NDI) output, which according to the doc, HD supports 1 of each, so at first glace that seems like it would work.
However, in the trail version, I see that External 1 is tied to the Program/broadcast output; I want something different for that output and I am using External 2 to send a specific input.
Should I assume that the HD version disables External 2 and that I only get External 1? If so, that doesn't work for me.
If it disabled External 1 and gave me the flexibility of External 2, then that would work, but I kind of doubt it works that way.
Other than this one question, all my other needs are met by HD.
Could someone please point me in the right direction? I can get $350 approved, but would hate to spend that and then have to go back and ask for more.
nikosman88
#2 Posted : Wednesday, December 27, 2023 4:48:24 AM(UTC)
nikosman88
Greece
Was thanked: 97 time(s) in 93 post(s)
Originally Posted by: sphbecker Go to Quoted Post
I am considering buying vMix to replace OBS for our quarterly company broadcast. I downloaded the trial and everything works as expected, however, I am unsure if I will need HR or 4K for my external output needs.
Hello. Yes in HD version it is disabled the 2nd external output so you cant do what you need. Output1/external1 is tied to program/stream/external in all vmix versions. If you need to send something else in other location than your master program.you will need to use external 2-4 that are not availiable in HD version. Also from vmix 27 that is in beta release for now, we will have 4 external outputs as 2-4 outputs will do also hw external output but in HD version it will continue the 1 external
thanks 1 user thanked nikosman88 for this useful post.
sphbecker on 12/27/2023(UTC)
