8 channel audio embedding on SDI
Joined: 1/6/2022(UTC) Posts: 12  Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Hello, I'm trying to embed 8 audio channels (MABC) on the SDI out of one of the Decklink DUO cards. (there are 2 in the PC) If I follow the manual, I should be able to select this in the external output options. But I don't get the audio output options in this tab... Cards are at version 12.7. and Vmix is at version 26.0.0.45. Anything else I am missing here... ? According to this it should work... https://www.vmix.com/hel...OutputAudioChannels.htmlWhat I have also tried : - Putting the audio outputs of ABC on the decklink card and putting them on channel 3-4, 5-6 and 7-8. - Also tried leaving them all on 1-2. Thank you.
Joined: 1/25/2019(UTC) Posts: 331  Thanks: 23 times Was thanked: 84 time(s) in 64 post(s)
 1 user thanked Peter1000 for this useful post.
Thank you but the problem lies in the last picture of your wiki. When I select the Decklink output, I don't get the tab audio channels...
I'm not sure if the old Decklink Duo has 8 channels. Do you have Duo or Duo2? Duo2 has all 16 channels in any case, of which vMix can use 8.
They are Decklink Duo 2 cards, still have the box...
Ok, so because no forum could provide me with an answer I reached out to Vmix support. Turns out the "recording audio" under Adio settings was corrupted.
Did a whole reset of Vmix and is was fixed.
I am really very sorry that we or I could not find out that your installation was faulty. Thanks to the vMix support team
