Frederik.A
#1 Posted : Tuesday, December 12, 2023 9:02:46 PM(UTC)
Frederik.A
I'm trying to embed 8 audio channels (MABC) on the SDI out of one of the Decklink DUO cards. (there are 2 in the PC)
If I follow the manual, I should be able to select this in the external output options.
But I don't get the audio output options in this tab...
Cards are at version 12.7. and Vmix is at version 26.0.0.45. Anything else I am missing here... ?
According to this it should work...
https://www.vmix.com/hel...OutputAudioChannels.html
What I have also tried :
- Putting the audio outputs of ABC on the decklink card and putting them on channel 3-4, 5-6 and 7-8.
- Also tried leaving them all on 1-2.
Thank you.
Peter1000
#2 Posted : Wednesday, December 13, 2023 12:59:01 AM(UTC)
Peter1000
Switzerland
Was thanked: 84 time(s) in 64 post(s)
See here
thanks 1 user thanked Peter1000 for this useful post.
Frederik.A on 12/13/2023(UTC)
Frederik.A
#3 Posted : Wednesday, December 13, 2023 1:07:35 AM(UTC)
Frederik.A
Thank you but the problem lies in the last picture of your wiki.
When I select the Decklink output, I don't get the tab audio channels...
Peter1000
#4 Posted : Wednesday, December 13, 2023 5:41:18 AM(UTC)
Peter1000
Switzerland
I'm not sure if the old Decklink Duo has 8 channels. Do you have Duo or Duo2? Duo2 has all 16 channels in any case, of which vMix can use 8.
Frederik.A
#5 Posted : Wednesday, December 13, 2023 6:34:31 PM(UTC)
Frederik.A
They are Decklink Duo 2 cards, still have the box...
Frederik.A
#6 Posted : Wednesday, December 13, 2023 7:33:15 PM(UTC)
Frederik.A
Ok, so because no forum could provide me with an answer I reached out to Vmix support.
Turns out the "recording audio" under Adio settings was corrupted.
Did a whole reset of Vmix and is was fixed.
Peter1000
#7 Posted : Thursday, December 14, 2023 12:59:01 AM(UTC)
Peter1000
Switzerland
I am really very sorry that we or I could not find out that your installation was faulty.
Thanks to the vMix support team
