Joined: 9/27/2019(UTC) Posts: 49  Location: Kuressaare
Hi.
How to make a script that works like this: if data changes in the Data Source JSON file, 1 row in both columns, run the graphic, it should be in front for 20 seconds and the graphic disappears, and every time like this.
Thank you for all your help :)
Joined: 12/27/2012(UTC) Posts: 5,442  Location: Belgium Thanks: 310 times Was thanked: 1004 time(s) in 829 post(s)
Thank you for all your help :) One can actually "program" the animation for that within a GT title itself (fixed delay time) else plenty of script examples (scripting for dummies post) on how to read title content (change) of a textblock and do some action (titleBeginAnimation) based on that
I don’t find where i get correct code..if JSON data change automatically start title graphics
Originally Posted by: NSCPro  I don’t find where i get correct code..if JSON data change automatically start title graphics if one uses a datasource ( be it json, xml, csv, ....) it is to link it to a title , one reads the content within the title and checks for a change there (script) same principle example here (reading through the API XML or using the input.find() function for title textblock content https://forums.vmix.com/...ng-for-Dummies#post71124https://forums.vmix.com/...ng-for-Dummies#post80518Can not expect to find an exact match for a personal goal but post contains some "tools/examples" to start from for creating your own "How to make a script that works like ... "
I make change in code. Overlay coming in and show Artist name and coming out too, but if song changes in JSON file. Graphics not comes up again. What i do wrong in this code
'Kena Raadio Data Source
dim Titlename as string = "TrackInfo" dim DataTableName as string = "Kena Raadio" dim oldartistname as string = "0" dim PAUSE As integer = 20000
dim ArtistName as string = ""
' put title in overlay 3 API.Function("OverlayInput3In",Input:=Titlename) Sleep(500)
API.Function("DataSourceSelectRow",Value:=DataTableName & ",0")
Do While True ArtistName = Input.Find("Titlename").Text("ArtistName.text") If not ArtistName = oldartistname API.Function("OverlayInput3In", Input:="3") API.Function("SetText",Input:=Titlename,SelectedName:=ArtistName & ".Text",Value:="") sleep(PAUSE) API.Function("OverlayInput3Out") oldartistname = ArtistName end if Sleep(500) Loop
Joined: 11/23/2020(UTC) Posts: 212  Location: Wichita Thanks: 11 times Was thanked: 28 time(s) in 24 post(s)
Originally Posted by: NSCPro  I make change in code. Overlay coming in and show Artist name and coming out too, but if song changes in JSON file. Graphics not comes up again. What i do wrong in this code ...
Try: Code:
Do While True
sleep(PAUSE)
end if
Sleep(1000)
Loop
This doesn’t work..I don’t know how this must be work :( If I add this line only in code Code:
Console.WriteLine(ArtistName)
Console show nothing, but must be show data
Originally Posted by: NSCPro  This doesn’t work..I don’t know how this must be work :( If I add this line only in code Code:
Console show nothing, but must be show data are those the correct names for your datasource, titlename and textblock names ? Code:'Kena Raadio Data Source
Do While True
ArtistName = Input.Find(Titlename).Text("ArtistName.text")
API.Function("OverlayInput3In", Input:=Titlename)
sleep(PAUSE)
end if
Sleep(1000)
Loop
or just build it into a title , no script needed Screenshot 2023-12-06 192851.jpg (172kb) downloaded 12 time(s).
Joined: 11/19/2015(UTC) Posts: 30  Location: Netherlands Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Cool, didn't this was possible. I was able to recreate your example. As soon as i change the title via webinterface, the title is activated. Let' see if uploading an example is possible:  Autotransition on change title.gtzip (8kb) downloaded 10 time(s).
