NSCPro
#1 Posted : Thursday, December 7, 2023 4:02:27 AM(UTC)
NSCPro
Estonia
Hi.
How to make a script that works like this: if data changes in the Data Source JSON file, 1 row in both columns, run the graphic, it should be in front for 20 seconds and the graphic disappears, and every time like this.
Thank you for all your help :)
#2 Posted : Thursday, December 7, 2023 4:25:45 AM(UTC)
Originally Posted by: NSCPro Go to Quoted Post
Hi.
One can actually "program" the animation for that within a GT title itself (fixed delay time)
else
plenty of script examples (scripting for dummies post) on how to read title content (change) of a textblock and do some action (titleBeginAnimation) based on that
NSCPro
#3 Posted : Thursday, December 7, 2023 4:45:58 AM(UTC)
NSCPro
Estonia
I don’t find where i get correct code..if JSON data change automatically start title graphics
#4 Posted : Thursday, December 7, 2023 5:05:26 AM(UTC)
if one uses a datasource ( be it json, xml, csv, ....) it is to link it to a title , one reads the content within the title and checks for a change there (script)
same principle example here (reading through the API XML or using the input.find() function for title textblock content
https://forums.vmix.com/...ng-for-Dummies#post71124
https://forums.vmix.com/...ng-for-Dummies#post80518
Can not expect to find an exact match for a personal goal but post contains some "tools/examples" to start from for creating your own "How to make a script that works like ... "
NSCPro
#5 Posted : Thursday, December 7, 2023 5:21:38 AM(UTC)
NSCPro
Estonia
I make change in code. Overlay coming in and show Artist name and coming out too, but if song changes in JSON file. Graphics not comes up again. What i do wrong in this code
'Kena Raadio Data Source
dim Titlename as string = "TrackInfo"
dim DataTableName as string = "Kena Raadio"
dim oldartistname as string = "0"
dim PAUSE As integer = 20000
dim ArtistName as string = ""
' put title in overlay 3
API.Function("OverlayInput3In",Input:=Titlename)
Sleep(500)
API.Function("DataSourceSelectRow",Value:=DataTableName & ",0")
Do While True
ArtistName = Input.Find("Titlename").Text("ArtistName.text")
If not ArtistName = oldartistname
API.Function("OverlayInput3In", Input:="3")
API.Function("SetText",Input:=Titlename,SelectedName:=ArtistName & ".Text",Value:="")
sleep(PAUSE)
API.Function("OverlayInput3Out")
oldartistname = ArtistName
end if
Sleep(500)
Loop
Roy Sinclair
#6 Posted : Thursday, December 7, 2023 11:51:38 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Try:
Code:
Do While True
            sleep(PAUSE)
      end if
Sleep(1000)
Loop
NSCPro
#7 Posted : Friday, December 8, 2023 2:59:23 AM(UTC)
NSCPro
Estonia
This doesn’t work..I don’t know how this must be work :(
If I add this line only in code
Code:
Console.WriteLine(ArtistName)
Console show nothing, but must be show data
#8 Posted : Friday, December 8, 2023 3:26:31 AM(UTC)
Code:
are those the correct names for your datasource, titlename and textblock names ?
Code:
Do While True
      ArtistName = Input.Find(Titlename).Text("ArtistName.text")
            API.Function("OverlayInput3In", Input:=Titlename)
            sleep(PAUSE)
      end if
Sleep(1000)
Loop
or just build it into a title , no script needed
Screenshot 2023-12-06 192851.jpg (172kb) downloaded 20 time(s).
ovonder
#9 Posted : Monday, December 11, 2023 10:33:46 PM(UTC)
ovonder
Cool, didn't this was possible.
I was able to recreate your example. As soon as i change the title via webinterface, the title is activated.
Let' see if uploading an example is possible:
Autotransition on change title.gtzip (8kb) downloaded 10 time(s).
Guest (5)
