Joined: 11/22/2023(UTC) Posts: 1  Location: SD Thanks: 1 times
I have a streaming server (flussonic) which I use to receive video from some remote studios, I use the in-stream-VLC option, the issue is that when I use the url with http, it works correctly but if I use the https, it does not load the video. Could it be that vmix does not work with the https protocol?
Joined: 4/23/2017(UTC) Posts: 1,488  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Well, very likely as there is no way to handle the encryption I guess. If you need remote streams getting into your system take a look at SRT inputs or use NDI remote freely.
 1 user thanked mavik for this useful post.
