danilegrullon
#1 Posted : Wednesday, November 22, 2023 1:16:38 AM(UTC)
danilegrullon
Dominican Republic
I have a streaming server (flussonic) which I use to receive video from some remote studios, I use the in-stream-VLC option, the issue is that when I use the url with http, it works correctly but if I use the https, it does not load the video. Could it be that vmix does not work with the https protocol?
mavik
#2 Posted : Wednesday, November 22, 2023 3:00:31 AM(UTC)
mavik
Well, very likely as there is no way to handle the encryption I guess. If you need remote streams getting into your system take a look at SRT inputs or use NDI remote freely.
danilegrullon on 11/22/2023(UTC)
