jmba
#1 Posted : Monday, December 15, 2014 12:52:35 AM(UTC)
jmba
Hi
I have a suggestion for slide show settings. Would it be possible to change the duration each photo/ slide is visible (transition) from full seconds as it is at the moment to milliseconds, the reason I ask, every so often I have to match a number of slides to the duration of music and the full seconds are too crude to make it work.
Kind Regards
Mike
Similar Topics
Automatically restore unpinned Slide Show Settings (Feature Requests)
by richardgatarski 2/23/2017 1:42:01 PM(UTC)
