Joined: 12/15/2014(UTC) Posts: 5 Location: New Zealand
Hi I have a suggestion for slide show settings. Would it be possible to change the duration each photo/ slide is visible (transition) from full seconds as it is at the moment to milliseconds, the reason I ask, every so often I have to match a number of slides to the duration of music and the full seconds are too crude to make it work. Kind Regards Mike
