yhlee1
#1 Posted : Monday, October 23, 2023 5:33:55 PM(UTC)
yhlee1
Korea, Republic Of
I am currently using OverlayInput1In & OverlayInput1Out to turn the overlay on and off(https://www.vmix.com/help25/index.htm?DeveloperAPI.html).
Now, I want to give a duration to OverlayInput1In, so when the overlays is turned on, and get turned off after duration.
is there any useful API for that?
kross
#2 Posted : Monday, October 23, 2023 5:56:52 PM(UTC)
kross
Was thanked: 44 time(s) in 43 post(s)
Yes. Hit the gear icon for the input, go to Triggers. Add a new trigger. The trigger should be "OnOverlayIn". The function to execute should be "OverlayInput1Out" (or whatever overlay # you're using). And for delay put how long you want the overlay to stay on screen, in milliseconds. So for 5 seconds put 5000.
