I am currently using OverlayInput1In & OverlayInput1Out to turn the overlay on and off(https://www.vmix.com/help25/index.htm?DeveloperAPI.html). Now, I want to give a duration to OverlayInput1In, so when the overlays is turned on, and get turned off after duration.
is there any useful API for that?
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
Yes. Hit the gear icon for the input, go to Triggers. Add a new trigger. The trigger should be "OnOverlayIn". The function to execute should be "OverlayInput1Out" (or whatever overlay # you're using). And for delay put how long you want the overlay to stay on screen, in milliseconds. So for 5 seconds put 5000.
