Instant Replay
ReplaySource after Video-FX
Hi all is it possible to include the LUT FX I put on my Inputs to equalize my 4 Cameras to the Replay-Clips? As far as I noticed, the Clip by default is created on the "blank" input-material... Any ideas anyone? Best regards and thx
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
The usual approach is to go to Settings->Outputs, and select Output 2, 3, or 4 (1 is reserved for streaming/recording), and select the input for your camera. Then in the instant replay settings, instead of specifying the input directly, select output 2, 3, or 4 as defined before. Unfortunately the number of outputs is limited. so if you have more than 3 cameras that you want to do this with, you may be out of luck. In that case, you'll need to put in a feature request. :)
Instant Replay
