JoKo
#1 Posted : Monday, October 23, 2023 5:01:40 AM(UTC)
JoKo
Germany
Hi all
is it possible to include the LUT FX I put on my Inputs to equalize my 4 Cameras to the Replay-Clips?
As far as I noticed, the Clip by default is created on the "blank" input-material...
Any ideas anyone?
Best regards and thx
kross
#2 Posted : Monday, October 23, 2023 11:43:38 AM(UTC)
kross
Was thanked: 44 time(s) in 43 post(s)
The usual approach is to go to Settings->Outputs, and select Output 2, 3, or 4 (1 is reserved for streaming/recording), and select the input for your camera. Then in the instant replay settings, instead of specifying the input directly, select output 2, 3, or 4 as defined before. Unfortunately the number of outputs is limited. so if you have more than 3 cameras that you want to do this with, you may be out of luck. In that case, you'll need to put in a feature request. :)
