spinfold
#1 Posted : Thursday, October 19, 2023 11:59:18 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
With SetText you can also specify the GT Title layer you are targeting.
However this option currently doesn't exist when using the countdown options (StartCountdown, StopCountdown, SetCountdown, etc)
This should be an easy one to add?
#2 Posted : Friday, October 20, 2023 3:00:38 AM(UTC)
Yes you can !
spinfold
#3 Posted : Friday, October 20, 2023 4:08:00 AM(UTC)
spinfold
Yes you can !
Hmm. I'll try again tomorrow, but it didn't seem to work for me earlier and it's not listed in the help documentation.
#4 Posted : Friday, October 20, 2023 4:10:17 AM(UTC)
Yes you can !
but (also) you get the option when creating a shortcut
spinfold
#5 Posted : Friday, October 20, 2023 4:21:02 AM(UTC)
spinfold
Yes you can !
I don't use shortcuts, everything is through the API. I'll try again when next at the machine!
#6 Posted : Friday, October 20, 2023 4:28:55 AM(UTC)
Even so, they often give an indication of the options available even if you never use them ;-)
Code:
API.Function("StartCountdown",Input:="name.gtzip",SelectedName:="Description.Text")
API.Function("StartCountdown",Input:="name.gtzip",SelectedIndex:="1")
work just fine
