Feature Requests
Allow SelectedName on countdown options
Joined: 1/23/2022(UTC) Posts: 131  Location: Milton Keynes Thanks: 14 times Was thanked: 14 time(s) in 14 post(s)
With SetText you can also specify the GT Title layer you are targeting.
However this option currently doesn't exist when using the countdown options (StartCountdown, StopCountdown, SetCountdown, etc)
This should be an easy one to add?
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: spinfold  With SetText you can also specify the GT Title layer you are targeting.
This should be an easy one to add? Yes you can !
Originally Posted by: doggy  Originally Posted by: spinfold  With SetText you can also specify the GT Title layer you are targeting.
This should be an easy one to add? Yes you can ! Hmm. I'll try again tomorrow, but it didn't seem to work for me earlier and it's not listed in the help documentation.
Originally Posted by: spinfold  Originally Posted by: doggy  Originally Posted by: spinfold  With SetText you can also specify the GT Title layer you are targeting.
This should be an easy one to add? Yes you can ! Hmm. I'll try again tomorrow, but it didn't seem to work for me earlier and it's not listed in the help documentation. but (also) you get the option when creating a shortcut
Originally Posted by: doggy  Originally Posted by: spinfold  Originally Posted by: doggy  Originally Posted by: spinfold  With SetText you can also specify the GT Title layer you are targeting.
This should be an easy one to add? Yes you can ! Hmm. I'll try again tomorrow, but it didn't seem to work for me earlier and it's not listed in the help documentation. but (also) you get the option when creating a shortcut I don't use shortcuts, everything is through the API. I'll try again when next at the machine!
Originally Posted by: spinfold  I don't use shortcuts,
Even so, they often give an indication of the options available even if you never use them ;-)Code:API.Function("StartCountdown",Input:="name.gtzip",SelectedName:="Description.Text")
API.Function("StartCountdown",Input:="name.gtzip",SelectedIndex:="1")
work just fine
Feature Requests
