Feature Requests
vMix 27 feature request for Scripting
Groups: Guests
Would it be possible to create a function that took a numeral value as an argument. Example: function SetPage(PageIndex as Integer, InputIndex as Integer) API.Function("SetPageIndex", Input:=InputIndex, Value:=PageIndex) end function SetPage(1, 7) This then becomes a public script that can be called. Also, offer the option to include a reference vb file that has all the functions rather than retyping them over and over again. Also, upgrade the Scripting interface to allow for sorting and or possible categories
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: social_wp@outlook.com  Would it be possible to create a function that took a numeral value as an argument. Example: function SetPage(PageIndex as Integer, InputIndex as Integer) API.Function("SetPageIndex", Input:=InputIndex, Value:=PageIndex) end function SetPage(1, 7) This then becomes a public script that can be called. Guess one is better of making external scripts/apps then for full control of coding/scripting and power. Can be called from a vMix script with an external process call ALso consider using dynamicinputs and values within vMix scripts. JMO
Feature Requests
