WatsonPrunier
#1 Posted : Thursday, September 28, 2023 1:11:00 AM(UTC)
WatsonPrunier
Groups:
Would it be possible to create a function that took a numeral value as an argument.
Example:
function SetPage(PageIndex as Integer, InputIndex as Integer)
API.Function("SetPageIndex", Input:=InputIndex, Value:=PageIndex)
end function
SetPage(1, 7)
This then becomes a public script that can be called.
Also, offer the option to include a reference vb file that has all the functions rather than retyping them over and over again.
Also, upgrade the Scripting interface to allow for sorting and or possible categories
#2 Posted : Thursday, September 28, 2023 1:45:03 AM(UTC)
Example:
end function
SetPage(1, 7)
Guess one is better of making external scripts/apps then for full control of coding/scripting and power. Can be called from a vMix script with an external process call
ALso consider using dynamicinputs and values within vMix scripts.
JMO
