	Hardware Compatibility
	Display large preview of an input in windowed mode
 Joined: 8/17/2023(UTC) Posts: 12  Location: Rio de Janeiro
                I would like to see a preview of an input or the preview of the MultiView in windowed mode, is it possible somehow?
  I know I can use the fullscreen to see the Multiview, but for me thats not an option because I have only 1 34" ultrawide monitor.
  If we could unpin an input like we can with audio Mixer or Instant Replay, that would be perfect.
  The Option "Display a large preview of this input" also does not help me, because I need to see this input all the time.
  Any ideas how can I do this?
 Joined: 7/27/2022(UTC) Posts: 31  Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
                Originally Posted by: fva  I would like to see a preview of an input or the preview of the MultiView in windowed mode, is it possible somehow?
  Any ideas how can I do this?  option1: send the multiview to NDI for example, put the multiview to Output 2 and turn on NDI. then you can open NDI STUDIO MONITOR and see the multiview there option2: or if you have another machine, open vMix on another PC/Laptop connected to same network, and then add NDI input and then select the multiview so you can monitor it there option3: if you don't have another machine or you have no NDI Studio Monitor installed, another option is to open another instance of vMix and you can add NDI input there and select your multiview or add camera input, and tick Legacy, and select External Output 2 as your camera input option4: Just open the input settings of your multiview input and it will be in window mode, so you can view it as a separate window and place it in a corner or where ever you like. i hope this helps.
