Using selected data source rows to fill additional titles.
Joined: 9/5/2020(UTC) Posts: 38  Location: brisbane Thanks: 2 times
Scenario - during the football game I use a title to display try scorers name - select data sourcefrom list and then and overlay the title.
Id also like to display a list of try scorers at the end of the game.
Ideally - when i trigger the try scorer's name during the game - if vmix could take this data and use it to fill a field in a game summary title - well that would be great.
I have no idea about potential workflow to make this happen.
If anyone has any ideas id really appreciate it.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: adambou  Scenario - during the football game I use a title to display try scorers name - select data sourcefrom list and then and overlay the title.
one idea: Every time a scorer name is displayed (triggered) call a script to write data pulled from the title and other details to add to a (CSV) Data Source file. Use that datasource file to populate your summary title
Brilliant idea.
Ive done lots of scripting but didnt know you could pull data from a title and add it to a CSV.
This would be the perfect solution. Whats the function for that?
This would be the perfect solution. Whats the function for that? see "scripting for dummies"post for examples of geting data from a title (retrieving by pulling it form the API XML or using Input.Find() CHeck vb.net on how to write to a txt/csv file to use within a script
